Proximity client x86
jorgejmrv6
Se puede instalar en cliente proximity en Windows 32 bits??
Patrick Sparkman
Proximity only supports 64-bit Windows, and there is no plans to support for 32-bit.
Troubleshooting Guide - Cisco Proximity
proximity-32-bit
why-only-64-bits-windows-client
Como puedo hacer para que funcione en win x86?
Hay alguna manera de usar proximity en un sistema de 32 bits?
Since Proximity only works with Windows 64-bit, it will not work on a 32-bit system.
