Proxying SIP Registrations
Justin Ferello
Level 5
Level 5
Can someone provide any valuable reasons to proxy SIP registrations from the VCS-E to the VCS-C, or why people do this?  The only response I have heard is that people think this is more secure, if so I do not understand how.
Justin
Thank you,
Justin Ferello
Technical Support Specialist, ScanSource KBZ
What Justin is referring to is where TelePresence endpoints that would typically register to the VCS-E would instead register to the VCS-C if SIP registration proxy mode was enabled.
I've heard of the same example "it's more secure", the only thing that comes to mind is trying to limit what the VCS-E has access to on the network since it's public facing, whereas the VCS-C is internal, so it can have full access to AD and other services without too much concern.
Dennis Mink
Not sure I fully understand your question, but the VCSe typically proxies SIP registrations on Mobile Jabber clients then passes the FW trough the traversal connection between VCSe and c.
Please rate if useful
Please remember to rate useful posts, by clicking on the stars below.
