QoS incorrect marking from TX9000 Please help
pierotizzone
Hi Guys,
We are currently trying to mark packets with AF41 but it seems like the TX is not marking the packets correct any help will be much apprectiated
Hi Piero,
We can see your traffic from IP 10.24.2.9 is coming in with incorrect markings, there is 80 CS4 and 00 BE instead of 88 AF41.
104194-neo-rb-1v#sh ip cache verbose FLOw | in 10.24.2.9
Fa0/1          10.24.2.9       Fa0/0.1066     172.31.72.11    11 80  10    3948
Fa0/1          10.24.2.9       Fa0/0.1066     172.31.72.11    11 80  10    1136
Fa0/0.1066     172.31.72.11    Fa0/1          10.24.2.9       11 88  10    6486
Fa0/0.1066     172.31.72.11    Fa0/1          10.24.2.9       11 20  10      75
Fa0/0.1066     196.26.5.10     Fa0/1          10.24.2.90      11 30  10       1
Fa0/0.1066     172.31.72.39    Fa0/1          10.24.2.90      06 88  18       1
Fa0/1          10.24.2.9       Fa0/0.1066     172.31.72.11    11 80  10    6694
Fa0/1          10.24.2.9       Fa0/0.1066     172.31.72.11    11 80  10     117
Fa0/0.1066     172.31.72.11    Fa0/1          10.24.2.9       11 88  10    4020
Fa0/0.1066     172.31.72.11    Fa0/1          10.24.2.9       11 20  10      86
Fa0/1          10.24.2.9       Fa0/0.1066     172.31.72.11    06 00  10       2
Fa0/1          10.24.2.9       Fa0/0.1066     172.31.72.11    06 00  10       1
Fa0/1          10.24.2.9       Fa0/0.1066     172.31.72.11    11 80  10    6976
Fa0/1          10.24.2.9       Fa0/0.1066     172.31.72.11    11 80  10    1143
Fa0/0.1066     172.31.72.11    Fa0/1          10.24.2.9       11 88  10      11K
Fa0/0.1066     172.31.72.11    Fa0/1          10.24.2.9       11 20  10     123
Fa0/1          10.24.2.9       Fa0/0.1066     172.31.72.11    11 80  10      11K
Fa0/1          10.24.2.9       Fa0/0.1066     172.31.72.11    11 80  10     190
Fa0/0.1066     172.31.72.11    Fa0/1          10.24.2.9       11 88  10    7023
Fa0/0.1066     172.31.72.11    Fa0/1          10.24.2.9       11 20  10     140
Fa0/0.1066     172.31.72.11    Fa0/1          10.24.2.9       06 20  10
Paul Anholt
Hi Pietro,
The TX9000 (and all CTS Codecs) will use the DSCP value configured on the Call Manager for TelePresence calls, and the default value for this is CS4. You can check this value on the codec by logging onto the GUI of the codec and clicking the "Telephony Settings" link on the left hand side.
If you need to change this setting you can do so by logging onto the CUCM GUI and navigating to System > Service Paramaters > Server: Select a server, Service: Cisco CallManager > DSCP For TelePresence Calls.
You will need to apply config or reboot the TX9000 for the changes to take affect.
Paul
