QOS marking testing
t.gupta
We had telepresence system in our office and implemented QOS in the network.We want to check the QOS marking in a network for our telepresence system during point to point call but we had restriction that we cannot use he wireshark software in our campus.
IS their any purticular tool that we can check the QOS marking in a network when their is call
we are using two 3010 telepresence systems.
Tarun
Tyler Wilkin
Hi Tarun,
You can check this in the sysop log files which are viewable form the GUI. Whenever the markings change (usually because the codec starts receiving media) you'll see log entries like the following. This is always what the codec is receiving.
2013-02-23 21:23:47: INFO Audio DSCP Current Marking: [EF], Previous Marking: [EF]
2013-02-23 21:23:47: INFO Audio COS Current Priority: [0], Previous Priority: [0]
2013-02-23 21:23:47: INFO Video DSCP Current Marking: [AF41], Previous Marking: [AF41]
2013-02-23 21:23:47: INFO Video COS Current Priority: [0], Previous Priority: [0]
I believe you can also check the DSCP markings of media you are receiving in a live call the GUI under Call Statistics. To see what we are marking sent packets, check Telephony Settings in the GUI. This is set from Call Manager under System -> Service Parameters.
Tyler Wilkin
TAC TelePresence
Thanks Tyler I will check and update you
regards
Tarun
daniel.bloom
Another option could be to export netflow statistics to a netflow collector, if there are netflow capable devices in the media path.
Thanks both of you
i had checked from the browser it had shown the marking during the call
Tarun
