QOS over video
tbui
I'm trying to implement Qos over video. I currently have 2 Tandberg video units, one at each end of a T1 circuit. I have tried LLQ but some reason it doesn't work.. Could someone can send me the Qos configuration please?
Thanks in advance
Tbui
juan-santamaria
Hi, I was use the followin link, for apply LLQ. It is very usefull
http://www.cisco.com/en/US/tech/tk652/tk701/technologies_configuration_example09186a0080111c1b.shtml
but I use Frame Relay to 1Mbps with 3 PVC .
Your Tandberg is very flexible for manages QoS. For best practice You could use Diff Serve in the ACL
sachon
what kind of routers are you using with what interfaces? How are you prioritizing the video traffic to use the LLQ? What other traffic is using the pipe? How much b/w is allocated for video? What b/w video calls are you requesting? When you say LLQ "doesn't work" - can you elaborate? what are you seeing? Need more detail to be of any help
