qos packet merking in ctms
alex goshtaei
HI All,
we are using couple of cts endpoints with ctms. cts endpoints marks the video packet as cs5, and I want to check cs5 packets coming to the ctms. is there a way in ctms to check qos marking of packets coming to it from cts endpoint? I've checked call statistics detail in ctms, but it doesn't show packet marking.
thanks
ALex
Johan Vermaelen
Alex,
You may find it in the log files, but the fastest way to find out would be to setup a call and do a small packet capture from the CTMS cli as follows:
- utils network capture 1000 file size ALL
will capture 1000 packets in the filename you specify
- file get activelog platform/cli/
will allow you to copy that file to an sftp server and open the capture with for example wireshark
Hope that helps,
Johan
