QSL Express requiered to TMS
gken2015moncada
what versions of SQL Express is recommended for install TMS ?
note: i have window server 2012
         TMS  ver 15.1
is recommended use SQL Express 2014 ?
Patrick Sparkman
You should refer to the TMS Install Guides for the recommended server and software versions.
For TMS 15.1, you can use:
  • Microsoft SQL Server 2012, All versions, 64-bit only
  • Microsoft SQL Server 2008 R2, All versions, 64-bit only
SQL 2014 isn't supported yet with any version of TMS.
