Quality issues with CUCM 8.6
manuelsanchez
Hello, I am experiencing quality issues on my TP systems (packet lost, sessions going down, unregistered endpoints...) since I upgraded to 8.6.2.20000-2.
Is there any known issue with this version?
Manuel
Rafal Szeremeta
Hi Manuel
What version did you have before? Are you using same platform?
Did you verify NIC settings, duplex, ect?
Rafal
I was on a 7.1.5 before running on a MCS.
Now we have moved to UCS.
I have check the NIC settings and everything looks fine.
Manuel
Hi Manuel,
Though this doesn't match all of your symptoms, this change comes to mind and is worth verifying: DSCP for TelePresence Calls introduced with CUCM 8.0 and CTS 1.7.4.
Paula
jmunoz19
Level 4
Level 4
Hi Manuel, FYI, that version of CUCM isn't supported in a TelePresence environment.  You might want to upgrade to CUCM 8.6(2a)SU2.
Check out the matrix:
http://www.cisco.com/en/US/docs/telepresence/cts_admin/1_8/compatibility/cts_compatibility_master.html
Thanks,Jeff
