02-02-2016 08:20 AM - edited 03-18-2019 05:31 AM
Hi Folks,
If a SX20 or SX 80 are registered SIP with a IP based PBX for telephony service to the system and using H.323 to dial out to video systems, do they have the capability of adding the SIP based Telephony caller to a point to point video call without a multi-site license on the endpoints? I believe that the MXPs used to have this capability but didn't think it made it to the SX series codecs. Thanks for your help!
02-02-2016 10:08 AM
Just curios, what is your IP PBX system you are referring to? CUCM or VCS?
You need multisite option installed on the SX20/80 endpoints to make multisite video call whether it's a combination of SIP or H323 calls. Without multisite option, adding another call will make the additional site to become an audio participant only.
regards,
Acevirgil
02-02-2016 10:18 AM
I don't believe the IP PBX is a Cisco product. So if there is a point to point video call connected and the client decides to add a telephone caller that's registered to their SIP based PBX they will be added on as a 3rd party as an audio only participant. So the call could accommodate a point to point video call and 1 audio caller w/o the multi-site option. If more video or audio sites would need to be added the multi-site option would need to be active. I just want to be clear with them what the multi-site option will buy them.
02-02-2016 11:29 AM
Yes. You're right. Multisite option is not needed if you add 1 audio participant only on the ongoing point-to-point call. But if additional video participant or more audio sites, you need the MS option.
regards,
Acevirgil
02-02-2016 12:13 PM
Thanks for your help Acevirgil, have a Great Evening!
