Redirecting Number Missing in Q931 Setup
Hi, I have the following problem. A redirected call comes from CUCM to H323 VGW and leave Pots  Dialpeer BRI S0 ISDN as a Q931 Setup Message. But redirected number is  not seeing in Outgoing Q931 Setup, only the Calling and Called Party  Number. CUCM is transmit redirected number fine to the VGW.
It should be transmitt also the Redirected Number at Pots Dialpeer Voice Port BRI S0.
Any help are appriciate.
Thanks in ahead.
HTH, please rate all useful posts!
Best Regards Armin
HTH, please rate all useful posts and right answers.
Jagpreet Barmi
Hi Armin,
Is the redirection done within the call manager?
Do you have "Redirecting Number IE delivery - Outbound" checked on the H323 gateway in the call manager? Please if not already, please check it and reset the gateway (off production hours).
HTH,
Jagpreet Singh Barmi
Hi, yes, it is a IP phone in CUCM they have CFA.
PSTN Call into VGW--> H323-- CUCM--> Ip Phone 106 Divert to 62225 ---> H323 ---- VGW ---- interface BRI0/1/0 --- S0 third party voice server
The Redirect Number recieve the IOS VGW. I see that in the Trace at  the Voice GW. I have found the problem now. After I set this Parameter
tkgwdemo(config-if)#isdn out ie redirecting-number
it works.
Here the config.
interface BRI0/1/0
description QSIG MRS
no ip address
isdn switch-type basic-net3
isdn overlap-receiving T302 3000
isdn protocol-emulate network
isdn layer1-emulate network
isdn incoming-voice voice
isdn outgoing display-ie
isdn outgoing ie redirecting-number
isdn static-tei 0
isdn skipsend-idverify
Nov 26 09:23:33.451: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x10
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x2181, '006157915399'
                Plan:ISDN, Type:National
        Called Party Number i = 0x80, '62991'
                Plan:Unknown, Type:Unknown
        Redirecting Number i = 0x00008F, '106'
