Regex TMS FindME Device Templates Problem
chrisman1337
i have a problem with a regex expression at the device templates section at TMS.
I want to use the first and last name, delete everything of first_name except the first letter. Then add the domain after it.
So for example: first_name is "chris". last_name is "man". For Device Address Pattern i used: {first_name['^[a-z]'\[a-z]+'='']}.{last_name}@domain.com.
The result is chris.man@domain.com.
So far so good. But i don´t get the expression, that only the first letter of "chris" is used. It should be c.man@domain.com
Can somebody give me a hint?
Kind regards
Chris Man
shawnangelo
Question, is c.man@domain the actual LDAP username?
Why not just match based on that as opposed to first_name last_name?
{username}@domain.com
I overthought that to but our LDAP name is for example "chrism" not "cman".
Patrick Sparkman
RegEx isn't supported and won't work in any of the template patterns that create FindMe and device addresses.  Instead TMSPE uses attributes to create the various addresses, see the "Creating Address Patterns" section of the TMSPE Deployment Guide starting at the bottom of pg 31 for the different attributes that is supported and used by TMSPE.
Okay, so i can´t modify the attributes? Thats bad...
Another thing is that {email} for example does not work. It seems that this is a bug.
