12-16-2014 06:22 AM - edited 03-18-2019 03:48 AM
Hi All,
VCS - x8.2.2
Polycom Group 300 - 4.1.5
Using H.323
As a last ditch attempt, we rebooted the VCS, and lo and behold the registration was successful both on the VCS and on the Polycom, and calls could once again proceed as normal, but obviously this is not an ideal way to resolve this issue. It has occurred on at least three occasions, and each time the only thing we could do was to reboot the VCS to resolve the issue.
Has anyone seen anything similar?
Cheers,
Chris
12-16-2014 09:30 AM
Is it a vcs-c or -e?
I would say it sounds like a firewall thing. Sure that there is nothing inbetween which
tampers with the registration?
Could be that the reboot of the VCS causes the firewall to flush the old entry.
But yea, can also be just an interoperability issue.
An other thing could be an e164 address conflict or just some interop issue, ...
12-22-2014 05:02 AM
The Polycom is registering to a VCS-C. The network is internal, and although I am not privy to the full network infrastructure, I believe that we have asked if there are any firewalls between the endpoint and VCS-C, and the answer was negative.
We setup registrations based on an allow list determined by E.164, I can categorically state that there is no E.164 conflict. The only device to use this E.164 is the Polycom itself. Also remember that the VCS is ALLOWING the Polycom to register, it just never seem to get a acknowledgement of that from the CODEC, so times out, only to allow registration again, and again, and again..... until rebooted.
The odd thing is, that if the Polycom is registered OK, and is then powered off and powered back normally, all seems to be OK. It has only been when there has been a disruption to the service (2 network, 1 power) that this problem occurs, and can only be rectified with a VCS reboot - which is less than ideal.
