reload wallpaper on cli
JensLantermann
Hi everybody,
I have created a little script, who push the wallpaper via winscp on to the codec.
Path is /users/posters witht the correct naming.
But the endpoint shows me a black screen, the xconfig parameter is set to custom.
So everything is correct, but black.
If I do a call and end them immediatly the new wallpaper will be displayed.
This looks like there is a reload of the wall paper missing.
How can I do that at the cli, without a reboot of the system?
regards Jens
Patrick Sparkman
What happens if you issue the wallpaper command after you upload it, does it refresh then?
xConfiguration Video Wallpaper: Custom
Note: command might be a little off, typing from memory.
Patrick Sparkman
Ok this works not really, but should be a workaroud.
1.xconfiguration Video Wallpaper: Summersky
2.xconfiguration Video Wallpaper: Custom
You must switch to another wallpaper and back to custom.
It is not the answere I was looking for, but ok.
What about not switching to the custom wallpaper until it's loaded?
