Remote Monitoring License for Room55
jjkim
Can someone please point me to the part number for adding Remote Licensing for Room55 units.  I see the option for Room Kits and the old L-TP-RM does not list Room55's as options.  The Remote Monitoring is not an option for configuration for the Room55 either.
Thank you
Wayne,
It looks like it's the L-Room-RM under the L-TP-RM Top Line Sku. Thanks for the assist.
5 Replies 5
Wayne DeNardi
L-ROOM-PAK with L-KIT-MS
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Thank you so much for your prompt reply.
Wayne,
I appreciate the reply but I noticed it is not the right software.  I'm looking for remote monitoring not the multisite software which is what you indicated.
Sorry, I typed the last bit.  Try L-ROOM-PAK with L-KIT-RM
Wayne
Wayne,
