10-17-2019 11:02 AM
Can someone please point me to the part number for adding Remote Licensing for Room55 units. I see the option for Room Kits and the old L-TP-RM does not list Room55's as options. The Remote Monitoring is not an option for configuration for the Room55 either.
Thank you
Solved! Go to Solution.
10-21-2019 03:22 AM
10-17-2019 03:35 PM
L-ROOM-PAK with L-KIT-MS
Please remember to mark helpful responses and to set your question as answered if appropriate.
10-17-2019 04:13 PM
10-18-2019 12:28 PM
Wayne,
I appreciate the reply but I noticed it is not the right software. I'm looking for remote monitoring not the multisite software which is what you indicated.
10-18-2019 01:07 PM
Sorry, I typed the last bit. Try L-ROOM-PAK with L-KIT-RM
10-21-2019 03:22 AM
