Renamed systems revert after a while
jonas.eriksson
Hi all,
Got an odd one. I am trying to rename a few systems in TMS but the old names keep popping back.
I am running TMS 13.1 and one of the systems is a Profile 8000MXP running F9.0.1.
I go into Edit Settings and change the name and H.323 ID, save and enforce management settings.
Logging in to the system I see it has the new name and all is fine. Then a day later the system has reverted back to the old name!?
Somebody please help clue me in. =)
Saurabh Gupta
Level 3
Level 3
Hi Jonas,
I would recommend to change the system name and other settings from the Tandberg MXP itself.
Once you do it, either refresh the management settings on that Paricular endpoint on TMS or just remove and re-add the endpoint in TMS again.
I hope this would solve your problem.
Saurabh
