Renewing TMS Server Certificate
Ayodeji Okanlawon
Gents,
Background
TMS 15.5.0
TMS is integrated with TMSXE
TMS is used for phonebooks using https and phones are managed using https
Just wanted to check with you all on the process of renewing TMS certs. I have already generated CSR using IIS. This is signed by a public CA. My questions are
1. Are there any other dependencies to consider for this
2. Any other thing to be aware of before renewing the cert?
Thank you
Please rate all useful posts
Patrick Sparkman
If you already have a certificate that you're renewing, you just need to contact the public CA that signed it to get a new one. There are no dependencies or issues that I'm aware of, TMS uses a standard certificate that can be used with IIS.
Patrick Sparkman
Thank you Patrick
