02-18-2015 01:23 PM - edited 03-18-2019 04:02 AM
Hi there, we recently installed and configured a Tx9200 system. Unfortunately the password has gone missing and I need to reset. Does anyone have instructions they can share for resetting?
Thanks in advance.
Solved! Go to Solution.
02-18-2015 03:33 PM
By default the TX9200 username is admin and the password is cisco.
If that doesn't work for you, you can use the pwrecovery user to reset the password. See the Resetting your CTS Codec Password section of the Admin Guide.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
02-18-2015 03:33 PM
Wayne
02-19-2015 01:56 PM
Thanks very much for this Wayne.
