Room Bar Pro - Output audio HDMI
joelcontreras1
Hello Cisco teams and users:
 I hope you're all well. I'm currently upgrading to a new device that a client purchased. They're replacing their old SX20 an adding a new Room Bar Pro. They used audio output through HDMI on the SX20 because it was connected to a central Creston speaker. However, I don't see audio output through HDMI on this new device in the datasheet. Is it possible to enable it somehow?
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/spark-room-kit-series/datasheet-c78-738752.html
Unlike the SX with its dedicated HDMI audio output, the BarPro has no HDMI output, only the listed options are available. The HDMI is for video to the screen, and audio via HDMI cannot be played through it while the Bar speaker outputs audio.
The optimal solution is to use the BarPro’s listed audio output options with the Crestron system.
Response Signature
It does audio output on the video output HDMI ports
Response Signature
Response Signature
Thank you for the response. Previous models did have this option, but this model doesn't.
Thanks for the clarification.
Cisco SX20 quick set
