Room Kit - Edit Wallpaper for Room scheduler.
Stephen M
We have the room bar in each conference room, A touch panel on the table and a room scheduler on the outside of the room. We are wanting to add a wallpaper on the room scheduler. The touch panel and room scheduler are the same device but in different modes.
The room bar connected to the TV has a wallpaper we set and the touchpanel on the table does also. But the room scheduler does not. There isnt a setting to add one. I have spend a lot of time working with Cisco tac with no luck. They sent me here.
Is there a macro that is able to add one to the room scheduler?
Many thanks.
You may have already worked this out by now (given your original post is 9 months old), but the newer versions of the RoomOS software allow a separate Scheduler Wallpaper for the scheduler in addition to the standard Wallpaper and Halfwake Wallpaper.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne
It seems to have changed again.
Now locally on Room OS (Personalization > "Wallpaper" and Halfwake"), we have :
- "Halfwake" : backgroup of screen and navigator in HalfWake state
- "Wallpaper" : backgroup on the screen when used
Now locally on a Navigator used as standalone for Scheduling (Personalization > "Wallpaper" and Halfwake"), we have a "Scheduler Wallpaper" which is the background of the navigator.
If we would like to configure globally on Control Hub, we need to go to "go to Devices and click Settings. Scroll to Branding."
We can set "Halfwake background" which seems to update "Halfwake" background of every Room bar.
We can also set "custom Room Scheduler Branding", which appears to update the "Scheduler Wallpaper" of the standalone Navigators.
But I can't find any global menu to update the "Wallpaper" (in wake up state) of the Room Bars...
Can you please advise ?
Best Regards,
