Room Kit Plus from Try&Buy Program: webex activation code missing
We received RK+ from Try&Buy Program.
What is the activation code to start testing?
Wayne DeNardi
The activation code is only needed if you are registering the endpoint to the Webex Cloud.  Did you also request this as part of the Try and Buy, or did you get it as an On-Prem registered endpoint?
If On-prem, you can skip the startup wizard and configure the device via the web interface or your call control platform.
If you are Cloud registering the device, contact whomever you organised the Try and Buy from, and they should be able to assist you with the required setup.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
