Room Kit Pro web interface login credentials
Logicalis
Is it any way to reset the web interface login for a Room Kit Pro in Control Hub without factory resetting the unit?  The default password of admin without no Passphrase has been change and no one know the new login information!
Thank you,
Jerome Boswell
PJMack
Level 7
Level 7
It is registered to control hub? As soon as you register it to control hub it disables the admin login. You can get to the endpoint web GUI from control hub,
Just click on launch in the local device controls section. It will open a new tab to the web GUI of the device (you have to be on a network that can route to the device. If you want to be able to log into the codec without going into CH you can go in this way and create a new user so it's accessible from a laptop without going through control hub.
Logicalis
Thank you PJMack I seen that option right after posting this question. I was wondering if it was another way, and you answer my question it is not. This client is looking a way to turn off the camera during a meeting from Control Hub.
