RS-232 Control port in webex room 55
skraj
Is it possible to control the Cisco web ex room 55 by using RS232 ? If yes , which one is the control port ? We can't find the RS232 port on the device.
Thanks.
Jonathan Schulenberg
You can use a USB-A to serial adapter. The default baud rate is 115200; see the command reference guide for more info.
