Same touch panel layout across SX and C series
Mike Kemp
We have a customer running a mix of C series and SX units and they would the touch screen to be the same across all units. Is this possible through software upgrading? Or will they have to swap out the C series for SX
/Mike
Patrick McCarthy
The C series will only work with the Touch 8, and newer SX's (10 and 80) are Touch 10 only. The SX20 can be used with either. So you won't have the same panel with C's and newer SX's, but if they are running the same TC software the GUI on the touch panel should be about the same aside for the  physical differences. On newer SX's though you might want to run CE code rather than TC, that's going to be the code base going forward.
Cheers Patrick thats great.
I assume the TC code has a different layout than the CE?
The layouts of the icons and options are about the same, but the overall look will be slightly different.  You can get an idea of the differences of both panels by looking at the Touch 8 User Guide (TC7.3) and Touch 10 User Guide (CE.2).
Note that you will lose features if you downgrade the SX units from CE to TC software.
Check these release notes: http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/software/ce8/release-notes/ce-software-release-notes-ce8.pdf
