03-20-2018 06:52 AM - edited 03-18-2019 01:59 PM
The screen mount kit is part of the Cisco Spark room Kit. Is there any idea to have the Cisco Spark room Kit PLUS used / installed as screen mount devices? Is this supported with some VESA material?
Solved! Go to Solution.
03-20-2018 07:12 AM
I'll assume you are talking about the Room Kit Plus with the Quad camera unit. Note this is two pieces, not one like the standard Room Kit that has speakers, camera, and codec all in the one unit.
The Room Kit Plus bundle comes with a wall mount kit for the quad camera (which has speakers too), and there is an optional wall mount for the codec itself. This hardware will generally be used with two screens, and in that setup you would want to center the cameras over the two screens, I suspect that's why there is no screen mount kit since it would not fit most use case scenarios.
See the datasheet - table 1.
Hope this helps.
03-20-2018 07:12 AM
Hope this helps.
