Serial Interface VoIP/RTP QoS
chrispresland
Hi there,
I'm wanting to setup some sort of VoIP/RTP QoS on a 2MB link between a satellite site and HQ. I have approx 20 handsets at the remote site. I have setup the following QoS rules on both remote and HQ routers, 2620's with IOS 12.2.
Router-HQ#sh run
call rsvp-sync
controller E1 1/0
class-map match-all class1
match access-group 101
policy-map policy1
class class1
bandwidth 2048
random-detect
random-detect precedence 0 32 256 100
interface Serial0/0
bandwidth 2048
encapsulation ppp
ip tcp header-compression iphc-format
ip rtp header-compression iphc-format
ip rtp compression-connections 64
ip rtp reserve 16384 100 800
Router-HQ#
I am trying to implement a more aggressive queue QoS method than just ip rtp header-compression?
Does anyone have any recommendations regarding my bodged attempt??
Much appreciated, Cheers!
Brandon Buffin
Take a look at the QoS SRND.
QoS SRND
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns432/c649/ccmigration_09186a008049b062.pdf
Specifically, look at the following sections.
WAN Aggregator QoS Design -> WAN Edge Classification and Provisioning Models
WAN Edge Link Specific QoS Design -> Frame Relay -> High-Speed
This should help you with classifying and prioritizing traffic.
Hope this helps. If so, please rate the post.
Brandon
Hi Brandon,
Apologies for the late reply!
Thanks for your input and guidance. I shall be applying some new configuration soon so will let you know how it turns goes!
Best Regards,
Chris
