Showing results forĀ
Search instead forĀ
Did you mean:Ā
Single Split Server Deployment CMS
Agor85
Hello all,
has somebody already successful deployed a CMS "Single Split Server Deployment", where the Core and Edge Module is on the same CMS Instance, just with two different IP interfaces (Internal / DMZ) - each interface mapped to one dedicated UCS physical switchport or VLAN?
Is this something which can be recommended ?
Brgds,
Tamas
Stephen Carr
You can certainly do it this way if you feel the need to keep the Callbridge and other core components separate VLAN-wise. The CMS doesn't care as everything is internal (it won't really be a split install, just a combined install with multiple interfaces). The key will be the DNS and cert management to make sure IPs match naming for each process (WebBridge vs TURN vs Callbridge vs XMPP).
Steve
