SIP Authentication for Jabber clients
ksherman
What protocol does the Jabber client use for SIP authentication?  I assume it's using HTTP digest based authentication per the SIP standard.  Is this true?
scoglass
SIP authentication typically occurs over port 5060 (TCP, UDP, SCTP) or securely over 5061 (TLS) as per RFC3261 regarding SIP as a transport.
Cisco follows these same standards and refers to the ports used for SIP communication in the Jabber Video Admin Guide.
http://www.cisco.com/en/US/docs/telepresence/endpoint/movi/admin_guide/JabberVideo_Admin_Guide_4-4.pdf
- Scott
