SIP Dialing Failing
brandonthor
We use our SX20's to connect to our WebEx rooms by dialing the WebEx Meeting ID @ourdomain.webex.com, and it works great.  Also connect to Zoom meeting using ID@zoomcrc.com with no issues.
I've noticed that when I've tried connecting to a different service (Pexip), which has a URL ending in .gov it will not connect.  Also tried connecting to Amazon Chime which is meetingid@meet.chime.in and get the message "Call cannot be completed as dialed".
Is there anything that would allow connecting to .com URI's, and not .gov or .in?  The odd thing is that looking at logs on VCSC, Expressway C&E the calls aren't even getting there.  What am I missing?
Edit to add that these SX20's are provisioned to Call Manager.
We do have SX20's at remote locations, that are provisioned to our Expressway-E box, and when calling from them, I see the logs on ExpyE.  Here is one, and I've changed the meeting #'s and domains...
Status
Status   Disconnected
Tag   459938aa-c9aa-430c-af41-6d151ab21df8
Box-unique call serial number   24af7e29-4ffd-4c53-a155-81ac5a807671
Source alias   sip:720227@ourdomain.edu
Destination alias   sip:meetingnumber@meet.chime.in
Start time   2018-11-29 11:40:24
End time   2018-11-29 11:40:27
Disconnect reason   487 Request Terminated
Duration   3 seconds
Call components
Local call serial number Source alias Destination alias Protocol Status Type
6c101557-d5bb-4171-b70c-9b75357675d7 sip:720227@ourdomain.edu sip:meetingnumber@meet.chime.in SIP <-> SIP 487 Request Terminated Expressway
Seeing above it seems your calls for .gov and .in not reaching to expressway-C.
Can you check whether you have proper SIP route patterns to route these calls to Exp-C?
And on Exp-C you should have search rule to route it to Exp-E
And on Exp-E you should have search rule to route these to DNS Zone.
Let me know if it helpful.
Thanks.
brandonthor
More Info...
I just tried dialing a jibberish URI of 23423@assdkjsdfk.com and another ending in .gov.  Only the one ending in .com shows in the Expressway logs.
Here are log files from the SX20 when trying to call the URI ending in .gov  Again, I've randomized any private data.
2018-11-29T22:05:02.016-06:00 a8 appl[1715]: 205222.13 MainEvents I: LayoutUpdated(p=1) outputNo=1 og=109
2018-11-29T22:05:02.017-06:00 a8 appl[1715]: 205222.14 MainEvents I: LayoutUpdated ...frame[GUI] gui p=1 src=1 ig=107 placeholder=0 avatar=0 x=0 y=0 w=10000 h=10000 l=0 b=0 letterbox fcref=0
2018-11-29T22:05:02.131-06:00 a8 appl[1715]: 205222.25 SipPacket I: SIP Msg: Incoming <= 404 Not Found, CSeq: 100 INVITE, Remote: CUCM.IP.Addr:5060, CallId: e08ff7ab30575e647f75ab0cb680662e
2018-11-29T22:05:02.131-06:00 a8 appl[1715]: 205222.25 SipPacket SIP/2.0 404 Not Found
2018-11-29T22:05:02.131-06:00 a8 appl[1715]: 205222.25 SipPacket Via: SIP/2.0/TCP sx20.IP.Addr:60578;branch=z9hG4bKde493aa2b7bde8eea371c296bc139c5d;rport
2018-11-29T22:05:02.132-06:00 a8 appl[1715]: 205222.25 SipPacket Call-ID: e08ff7ab30575e647f75ab0cb680662e
2018-11-29T22:05:02.132-06:00 a8 appl[1715]: 205222.25 SipPacket CSeq: 100 INVITE
2018-11-29T22:05:02.132-06:00 a8 appl[1715]: 205222.25 SipPacket From: "Brandons SX20" <sip:771119@ourdomain.edu>;tag=2a4969611f687c30
2018-11-29T22:05:02.132-06:00 a8 appl[1715]: 205222.25 SipPacket To: <sip:1675139@theirdomain.gov>;tag=9422694~a49a3bff-6613-432a-a9d1-c98e83407857-30037506
2018-11-29T22:05:02.132-06:00 a8 appl[1715]: 205222.25 SipPacket Server: Cisco-CUCM11.5
2018-11-29T22:05:02.132-06:00 a8 appl[1715]: 205222.25 SipPacket Date: Sun, 30 Nov 2018 04:04:52 GMT
2018-11-29T22:05:02.132-06:00 a8 appl[1715]: 205222.25 SipPacket Allow-Events: presence
2018-11-29T22:05:02.132-06:00 a8 appl[1715]: 205222.25 SipPacket Reason: Q.850 ;cause=1
2018-11-29T22:05:02.132-06:00 a8 appl[1715]: 205222.25 SipPacket Session-ID: 00000000000000000000000000000000;remote=bb7151876c44234d9bd9a51aa9422694
2018-11-29T22:05:02.132-06:00 a8 appl[1715]: 205222.25 SipPacket Content-Length: 0
2018-11-29T22:05:02.138-06:00 a8 appl[1715]: 205222.26 SipPacket I: SIP Msg: Outgoing => ACK, CSeq: 100 ACK, Remote: CUCM.IP.Addr:5060, CallId: e08ff7ab30575e647f75ab0cb680662e
2018-11-29T22:05:02.139-06:00 a8 appl[1715]: 205222.26 SipPacket ACK sip:1675139@theirdomain.gov SIP/2.0
2018-11-29T22:05:02.140-06:00 a8 appl[1715]: 205222.26 SipPacket Via: SIP/2.0/TCP sx20.IP.Addr:60578;branch=z9hG4bKde493aa2b7bde8eea371c296bc139c5d;rport
2018-11-29T22:05:02.141-06:00 a8 appl[1715]: 205222.26 SipPacket Call-ID: e08ff7ab30575e647f75ab0cb680662e
2018-11-29T22:05:02.141-06:00 a8 appl[1715]: 205222.26 SipPacket CSeq: 100 ACK
2018-11-29T22:05:02.141-06:00 a8 appl[1715]: 205222.26 SipPacket From: "Brandons SX20" <sip:771119@ourdomain.edu>;tag=2a4969611f687c30
2018-11-29T22:05:02.142-06:00 a8 appl[1715]: 205222.26 SipPacket To: <sip:1675139@theirdomain.gov>;tag=9422694~a49a3bff-6613-432a-a9d1-c98e83407857-30037506
2018-11-29T22:05:02.142-06:00 a8 appl[1715]: 205222.26 SipPacket Route: <sip:CUCM.IP.Addr;lr>
2018-11-29T22:05:02.142-06:00 a8 appl[1715]: 205222.26 SipPacket User-Agent: TANDBERG/528 (TC7.3.9.b938c8e) Cisco-SX20
2018-11-29T22:05:02.142-06:00 a8 appl[1715]: 205222.26 SipPacket Content-Length: 0
2018-11-29T22:05:02.143-06:00 a8 appl[1715]: 205222.26 SipStack I: SipDialog(ui=38,s=61) sendInviteRejToStack (404:Not Found)
2018-11-29T22:05:02.152-06:00 a8 appl[1715]: 205222.27 SipCall I: sip_call_handler::handleSIPMCallRej(38/61/-1): Call rejected (cause: Not Found)
2018-11-29T22:05:02.155-06:00 a8 appl[1715]: 205222.27 MainEvents I: CallDisconnectRequested(p=38) remoteURI='sip:1675139@theirdomain.gov' cause=[normal('') 'LocalDisconnect']
2018-11-29T22:05:02.159-06:00 a8 appl[1715]: 205222.28 MainEvents I: ActiveSpeakerIndication(c=35,p=1)
2018-11-29T22:05:02.170-06:00 a8 appl[1715]: 205222.29 MainEvents I: ParticipantLeftConference(c=35,p=38)
2018-11-29T22:05:02.173-06:00 a8 appl[1715]: 205222.29 AUDIOCTRL-0 W: rem lig 101 from mix 686 failed: gate not added to mix
2018-11-29T22:05:02.180-06:00 a8 appl[1715]: 205222.30 MainEvents I: CallDisconnected(p=38) remoteURI='sip:1675139@theirdomain.gov' causeToLocal=[fail_network_rejected('Call party not registered') 'NetworkRejected'] causeToRemote=[normal('') 'LocalDisconnect']
2018-11-29T22:05:02.205-06:00 a8 appl[1715]: 205222.32 Bfcp do_Ready_BFCPDiscReq
2018-11-29T22:05:02.208-06:00 a8 appl[1715]: 205222.33 Bfcp do_Ready_BFCPDiscReq session not found id=38
2018-11-29T22:05:02.269-06:00 a8 appl[1715]: 205222.39 MediaServerMsctrl I: CapabilityControllerImpl::setCapset() reductionLevel = 0, waitForDuoGate = 0, hasLegacyVideo = 0
2018-11-29T22:05:02.269-06:00 a8 appl[1715]: 205222.39 MainEvents I: ConferenceSessionReleased(c=35)
2018-11-29T22:05:02.277-06:00 a8 appl[1715]: 205222.39 CuilApp User admin(1001) about to execute command '/Call/DisconnectAll' from 111.222.111.222.
Thanks.
Thanks for the tip on where to look.  I added rules for the domains to the SIP Route Pattern on CUCM and it is working as it should.
Will this fix the endpoints we have at remote locations that are registering through Expressway E?  Do I need to do something for them as well?
If your internal endpoints are working fine then ideally it should work for MRA registered endpoints as well.
And in case if it is not working we need to take a look on logs.
Thanks.
Please rate if it is helpful.
