05-14-2018 05:07 AM - edited 03-18-2019 02:06 PM
In our environment only jabber is allowed.
I did the configuration for SIP domain pattern.
IMP domain: test.com
xmpp domain: conf.test.com
sip domain pattern : conf.test.com
sip trunk destination: cms-dc-core.test.com
incoming call in CMS :
domain name: conf.test.com
when i tried to make call from jabber user1@conf.test.com, the green button is not coming up.
Where im missing the configuration.
there is no jabber-confix.xml file in cucm tftp.
number dialing working to spaces; ex: 88XXXX but not user@conf.test.com even user@test.com not working between jabber calls. but with numbers i can make call.
Solved! Go to Solution.
05-15-2018 08:44 AM
You need to enable SIP URI dialing within Jabber, this is done by creating a jabber-config.xml file and uploading it CUCM.
05-15-2018 08:44 AM
05-15-2018 09:40 AM
05-15-2018 10:39 AM
05-15-2018 10:59 AM
05-15-2018 01:24 PM
05-15-2018 11:33 PM - edited 05-15-2018 11:44 PM
thank you patrick.
Im really confused about that. xmpp id we can only use when we are using CMA or webRTC. its working through webRTC. if you are using jabber then it should be using user URI part. ie acano1.meet@conf.test.com.
but in the display of jabber instead of showing acano1's space its showing acano1@<ip address of CUCM subscriber> ie acano1@172.17.58.12
why its so
