SIP Domain Pattern not working for CMS
jaheshkhan
Level 5
Level 5
In our environment only jabber is allowed.
I did the configuration for SIP domain pattern.
IMP domain: test.com
xmpp domain: conf.test.com
sip domain pattern : conf.test.com
sip trunk destination: cms-dc-core.test.com
incoming call in CMS :
domain name: conf.test.com
when i tried to make call from jabber user1@conf.test.com, the green button is not coming up.
Where im missing the configuration.
there is no jabber-confix.xml file in cucm tftp.
number dialing working to spaces; ex: 88XXXX but not user@conf.test.com even user@test.com not working between jabber calls. but with numbers i can make call.
Patrick Sparkman
You need to enable SIP URI dialing within Jabber, this is done by creating a jabber-config.xml file and uploading it CUCM.
Parameters Reference Guide for Cisco Jabber 12.0
Cisco Jabber Configurator 11.6
6 Replies 6
Patrick Sparkman
but now the issue is that domain part of URI is changed to IP address of CUCM.
In SIP Profile, already checked use fully qualified Domain name in SIP Requests.
also when im using XMPP ID for dial its not working.
acano1@conf.test.com = XMPP ID
acano1.meet=URI user part
when im dialing acano1.meet@conf.test.com it joins with acano1 space but conf.test.com is changed to CUCM subscriber IP address.
but when i dial with XMPP ID, acano1@conf.test.com it immediately fails.
May I know where im missing here?
Make sure that "Cluster Fully Qualified Domain Name" in CUCM Enterprise Parameters is configured with your SIP domain.
i did like this:
Organization Top Level Domain: test.com
Cluster Fully Qualified Domain Name: conf.test.com
but still didnt work. it gives teh same result.
Whenever you dial the user's address in CMS (acano1@conf.test.com), the user must be signed into the CMA/WebRTC client in order to answer the call, as that is calling the user and not their space (acano1.meet@conf.test.com).
Regarding the domain appearing as the CUCM IP address, what happens if you make a call from one Jabber client to another within CUCM?
thank you patrick.
Im really confused about that. xmpp id we can only use when we are using CMA or webRTC. its working through webRTC. if you are using jabber then it should be using user URI part. ie acano1.meet@conf.test.com.
but in the display of jabber instead of showing acano1's space its showing acano1@<ip address of CUCM subscriber> ie acano1@172.17.58.12
