04-09-2015 05:33 AM - edited 03-18-2019 04:18 AM
I noticed a change in IOS Gateways in how it deals with anonymous calls. Anonymous calls in version 12.4(25g) generates an SIP INVITE:
A anonymous calls on version 15.1(4)M8 generates a SIP INVITE:
The p-asserted-identity and remote-party-id did not change. None of our other SIP systems use the "anonymous@" format.
How do I get the 15.1 GW to use "<number>@" instead of "anonymous@" for these calls?
-John
04-10-2015 01:30 AM
Hi John,
The only possible solution that i could think of for this scenario is through the use of SIP profiles on the gateway. There are quite a few posts and docs which you can check to try and configure one for your setup
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/105624-cube-sip-normalization.html
http://www.gossamer-threads.com/lists/cisco/voip/127376
Manish
04-10-2015 05:36 AM
The SIP profile will not work since the phone number is not in the from header and I cannot pull variables from different rules. Otherwise I would pull the RPI value and place it in the from header.
Do you know why this was changed in IOS without a mechanism to revert back?
-John
