SIP-to-H.323 Connections fail
mkt.cisco
Dear all,
I can't make a following call.
SIPGW -> C2821 -> CUCM -> H323GW
H323GW returns "no resource (47)". Codec is G.729r8.
C2821 configuration is like,
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
sip
dial-peer voice 3 voip
description == H323 Side==
destination-pattern 1111....
session target ipv4:1.1.1.1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 11 voip
description == incoming call ==
incoming called-number .T
no vad
The opposite call is normal.
Any advices will be helpful. Thnaks in advance.
7 Replies 7
Adrian Saavedra
Level 7
Level 7
Hi friend,
Can you check codec settings? May be you can do a debug voice ccapi inout in your gateways.
In this link, you can find codec negotiation values (from debug voip ccapi inout).
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094045.shtml#codecnegvalues
- adrián.
Adrian Saavedra
Level 7
Level 7
Also, if this is a matter of codecs, may be you can check this:
"SIP Gateway G.729 Codec Type Mismatch
IOS Session Initiation Protocol (SIP) gateways are used to treat G.729 codec types G.729r8 and G.729br8 as interoperable, but according to RFC 3555 leavingcisco.com this is not true. IOS SIP gateways compliant to the RFC 3555 specification treat G.729r8 and G.729br8 as different codecs. This can cause codec mismatch problems if configured differently on the end points. This can happen with Cisco SIP end points such as the Cisco ATA 186/188, Linksys devices and SIP phones along with some third party SIP end points.
Solution
In IOS SIP gateways complaint to RFC 3555, you need to specify the exact G.729 type of codec in the configuration. Another solution is to downgrade the IOS to a version which is not RFC 3555 complaint. Refer to Enhanced Codec Support for SIP Using Dynamic Payloads for more information on G.729 codecs on SIP gateways."
- adrián.
Thank you for the reply.
I use surely codec as G.729r8 at the SIP endpoints.
I confirmed it by debug command. The current status is,
SIP sends INVITE with FS, however CUCM sends SETUP to H.323GW without FS.
Our SIP-GW doesn't send any TCS afterwards. Finally H.323GW(Cisco) returns "no resource (47)"
Should SIP-GW send TCS after sending INVITE with FS?
or CM should support FS by its setting?
P.S. Sorry for posting to wrong topics.
rzanett
Let me see if I am understanding this correctly:
You have a SIP trunk into the 2821. You then point to CUCM. Is this a SIP or H323 trunk to CUCM? Or are you then sending it to as an H323 to the H323 Gateway?
SIP --> 2821 --> H323 --> CUCM --> H323GW
Or
SIP --> 2821 -->SIP --> CUCM --> H323GW
It appears the first way. Let me know as I have all of the following working:
SIP Trunk --> IP-to-IP GW --> H323 to CUCM
SIP Trunk --> IP-to-IP GW --> H323 to Gatekeeper
SIP Trunk --> IP-to-IP GW --> SIP to CUCM
I had to implement transcoding on the router, as my SIP inbound to the gateway was G729 and I wanted to get it to G711.
Have a great day
Here are some code snippets:
voice service voip
sip
bind control source-interface Loopback10
bind media source-interface Loopback10
Bind your SIP to a loopback.
Bind your H323 to loopback:
description CUBE Source Loopback
ip address 10.1.1.1 255.255.255.255
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.1.1.1
Note: There are more commands that I have under this interface when registering this as a gateway to Gatekeeper.
The following are dial peers that I have setup to be able to manipulate how and where I send inbound calls to. The phone numbers have been changed but you will get the point. I am able to send calls in as H323 or SIP or to Gatekeeper, etc.
dial-peer voice 1 voip
description incoming-from Verizon
answer-address .
voice-class codec 1
session protocol sipv2
incoming called-number 188844422..
dtmf-relay rtp-nte digit-drop
no vad
dial-peer voice 200 voip
description SIP to Regional CUCM
preference 4
destination-pattern 188844422..
session target ipv4:10.31.255.68
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 201 voip
description H323 To Lab Regional CUCM
preference 2
codec g711ulaw
dial-peer voice 100 voip
description Outbound to Verizon
destination-pattern .T
voice-class codec 1
session target ipv4:172.30.201.17:5185
no vad
dial-peer voice 205 voip
description to Woodbury CUCM
destination-pattern 1888444222.
voice-class codec 1
session target ras
dial-peer voice 2 voip
description Incoming from CUCM
no vad
I also have transcoding resources setup on the router, which uses a subset of CME.
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a008092d6b3.shtml
Cheers,
Thanks for your information. As you noticed, I use H.323 between 2821 and CUCM.
In fact I need not to use Transcoder. Because codec is G.729r8 between SIP endpoints and H323GW.
can you provide a router configuration example of what you have working
