05-27-2011 06:45 AM - edited 03-17-2019 10:19 PM
Hi all, I'm trying to setup a video call between 9951 and IP door station 2N Helios IP that support H264 over SIP.
The audio call is working well but I see only black screen on my 9951, I don't see video also with other SIP client connected on the same CME 8.6.
This is my config:
voice service voip
no notify redirect ip2ip
clid network-provided
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback cisco
modem passthrough nse codec g711alaw
sip
registrar server
asymmetric payload full
voice register global
mode cme
source-address 192.168.99.204 port 5060
bandwidth video tias-modifier 512000 negotiate end-to-end
max-dn 20
max-pool 10
load 9951 sip9951.9-1-1SR1
authenticate presence
authenticate register
authenticate realm cme
timezone 23
date-format D/M/Y
tftp-path flash:
file text
create profile sync 0010244609221862
network-locale IT
user-locale IT
ntp-server 192.168.99.254 mode directedbroadcast
camera
video
voice register dn 1
number 200
allow watch
name 200
no-reg
label 200
voice register dn 2
number 201
allow watch
name 201
no-reg
label 201
voice register dn 3
number 202
allow watch
name 202
no-reg
label 202
voice register pool 1
id mac 0000.0000.0000
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
username 200 password xxxxx
codec g711ulaw
camera
video
voice register pool 2
type 9951
number 1 dn 2
presence call-list
dtmf-relay sip-notify
username 201 password xxxxx
codec g711ulaw
camera
video
voice register pool 3
number 1 dn 3
presence call-list
dtmf-relay rtp-nte
username 202 password xxxxx
codec g711ulaw
camera
video
Anyone have a CME with SIP video call working that can help me to debug my problem?
Enrico.
06-12-2011 06:01 AM
hi Enrico,
I have seen a similar issue with cme 8.6 .
Can you test with cme 8.5?
Karthik
12-08-2011 09:00 PM
Hi Enrico,
Did you finally got this to work...CUE 8.6 with the 9951 Video IP Phone ? I am trying to do similar with my customer...juyst proposal stage and they would like their UCS540W to be able to allow the 2N Helios IP Door phone to show the video on a 9971 IP Phone.
Cheers
Bob Sindhu
12-09-2011 12:38 AM
No, I don't found any solution and I have upgraded to CCM to do this.
Enrico
12-13-2011 10:10 AM
I think you may upgrade it CME 9 and Test, but seems you missed little bit of configuration..
How do you talk to the Door Phone? What is the number on it.?
Fransisku
12-11-2012 07:57 AM
It has been a few year since last update from epasqualotto.. I wonder if he could make it work couse I am having the same issue i got a 2h helio withouth display, just video camera.. and I want I to call a cisco 8941 video phone.. and I need to see the video on cisco 8941...
Thanks.
04-15-2013 05:07 PM
I got it to work by changing the H.264 payload type (1) to 0 and change the H.264 payload type (2) to 97. These settings are in the Advanced Settings->Video Codec->Advanced RTP settings. This fixed the no video on 99XX phones when calling from Helios Force door phone.
07-17-2013 01:27 AM
Hi William
i have same system here with 2N Helios with Callmanager Express 8.8.
Video and Audio works fine, but cannot get the door release working from the IP Phone.
Phone model is 9951.
can you please share some configuration to release the door from the ipphone 9951 keypad or with a speed dial button.
Really appreciate your help
shameer
07-17-2013 10:59 AM
Hello Shameer,
Looks like you have the difficult part of getting the voice and video working. To activate the door solenoid to release the lock, by default just press the zero key on the phone twice while in the call. You can change the key combination to something else to release the lock in the 2N gui application.
07-18-2013 01:32 AM
Hi William
Thanks for the response.
i have attached screen shots from 2N Admin page.
can you please check and let me know the settings are correct.
door is not opening by dialing 11 during the call or after call.
shameer
07-17-2013 01:29 AM
Hi Enrico
can you manage to get the door release working from 9951 to 2N Helios Door system.
i have video and audio working but cannot get the door to release from IPPhone.
can you share some configuration.
shameer
