SPA8000 & SPA2102 cannot receive 2 concurrent calls
kiwisupport
Hi there
We have a issue where a VoIP line is configured on line 1 of a SPA2102 ATA and cannot receive 2 concurrent incoming calls
Example:
First incoming call comes on line 1 -> phone rings (no one picks up)
Second incoming call comes on line 1 (while first call continue ringing) -> caller gets a busy tone (we want both calls to ring at the same time on line 1 not go to a busy tone)
Does anyone have a resolution to this or is this the limitation of the ATA VoIP hardware?
We have tested with a SPA2102, SPA800, PAP2T and they all do the same thing.
In my experience It's no possible because the first call is still in the setup phase. You can get the ring back tone only after a connection and configuring the call waiting service.
Best regards.
