Spark Room Kit in maintenance mode
carl1
How do you remove the Spark Room end point from maintenance mode ?
The quickest way will be to re-load the CE software on to the endpoint via the web interface.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Hello Wayne,
I did a Software Recovery Swap and I reloaded software ce9.1.4 but on both occasions the unit remained in maintenance mode after the reboot.
If you've re-loaded the software and done a factory reset and the device is still failing to boot normally and keeps coming up in Maintenance Mode, then I'd suggest that you log a call with the TAC as the unit may need to be RMA'd.
Wayne
