02-20-2017 10:06 AM - edited 03-18-2019 06:55 AM
Hi everyone,
Does anyone know if its possible to remove the ability for users to create new spaces from within the Cisco Meeting App?
Cant find anything in the API guide for this.
Solved! Go to Solution.
02-20-2017 03:00 PM
You can prevent users from creating Spaces by creating a user profile with "canCreateCoSpaces" set to false, take a look at section 9.3.2 of the CMS 2.1 API Guide. The ID of the created user profile will then need to be added to the top-level global profile under /system/profiles if you want it to affect everyone, or under /users/<user ID> if you want it to be for specific users only.
02-20-2017 03:00 PM
