08-05-2015 12:53 AM - edited 03-18-2019 04:49 AM
I am trying to use the streaming option at tandberg mxp device. I need nearly 200 people watch the video conference session but not attend. First i am trying at local lan but in the web interface when i start streaming i can't see any video at the screen in the web interface or when i enter the http://ip_address/stream.sdp to vlc player or quicktime player. How can i solve this?
08-05-2015 06:00 AM
Consider to check your firewall settings on your PC or anti virus running on your PC that blocks streaming application.
Try also to connect directly your PC on same switch where the MXP endpoint is connected just to isolate network connectivity issues.
regards,
Ace
08-05-2015 02:56 PM
PC is running windows 8 and firewall off, windows defender disabled
I am trying exactly like you said but no video at streaming page
08-05-2015 05:34 PM
Have you enabled streaming on the endpoint and enabled the remote start? You need to do this with the remote on the endpoint. Go to the Menu > Services > Streaming > Streaming Settings, then change the "Allow Remote Start" setting to "On".
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
08-06-2015 01:34 AM
08-06-2015 01:58 AM
Did you try this format:
http://ip_address/showstream.ssi ?
Also refer to this document under page 15, it might help you resolving your issue:
regards,
Ace
