09-15-2016 07:04 PM - edited 03-18-2019 06:22 AM
I need to connect a Crestron MC3 to a SX-10 and monitor codec wake/sleep.
No RS-232 port . . . how do I connect. I do not believe the Codec and MC3 will be on the same network so IP control is out. How do I get there?
thanks.
09-18-2016 01:04 PM
The methods to connect to and control the SX10 are outlined in the SX10 API Guide, which are: Telnet, SSH, or HTTP/S. There is a USB console port on the top back of the endpoint under a rubber cover, but according to the data sheet, its meant for debugging purposes only.
09-20-2016 06:49 PM
The SX10 isn't designed as an integrator endpoint, so anything like this will be an "unsupported" solution. But it can probably be achieved. Ideally, you'd have your SX and the MC3 on the same LAN, but if that's not possible, some of the Crestron DigitalMedia devices support CEC signalling, so you may be able to monitor the CEC from the SX when it wakes/sleeps and act accordingly.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
