11-14-2012 01:46 PM - edited 03-18-2019 12:08 AM
What is the proper way to connect these, we are using a shop made cable, xlr (mixer) to 4 pole mini ( +,- and grd only) but when they are pugged in the local audio drops and there is background noise and the far end incoming audio clips. Unplug the Shure mixer (set to mic level out) and all is well when using the codec mic.
10-07-2014 06:10 PM
have you ever gotten this to work?
10-08-2014 02:13 AM
maybe a groundloop issue - you could try to put a DI-Box with ground-lift-switch in between.
10-08-2014 04:25 PM
thank you.
01-29-2018 10:09 AM
How did you resolve this issue. I have similar problem in hand at the moment
01-29-2018 05:35 PM
There are a number of threads about this with solutions in the forums:
Please remember to mark helpful responses and to set your question as answered if appropriate.
