SX 20 Auto Call Reject
hjabrahams
Hi everyone. I'm trying to help one of my engineers out with a (seemingly) simple problem for which we can't seem to find a configuration setting to resolve it.
We've recently switched the auto-answer feature OFF on all our endpoints because of a security incident (should have been off from the beginning, but client wanted 'ease of use'). Unfortunately we now have a scenario where if someone dials a VC unit accidentally, the receiving unit will just ring continuously until the caller hangs up.
I'm looking to either:
  1. Set the receiving unit to reject the call after a certain number of rings, or
  2. Set the calling unit to give up trying after a certain period of no answer
Henri
Wayne DeNardi
What call control platform are you using?   If you're using a CUCM, you should be able to tweak the no answer timeout setting to something shorter if you are hearing it ring for too long.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
