I am currently using a SX-20 on a mobile cart device with a touch 8. Devices register to vcs and are setup in tms.
I am currently using the sx-20 and touch 8 behind a small router because I want the device to auto resync\connect the touchpad when its moved to another location. I can't assign statics because our different floors are on separate VLANs
The router setup does seem to work fine as long as I forward all the needed ports for communications.
Im forwarding
1720
5555-6555
2326-2485
5060 and 5061
TMS and VCS can communicate with the device with no problem and I can connect to the web front end just by browsing to the routers IP. The issue I am running into is how quickly tms updates the devices IP. If its changed.
Is there anything I can do to speed up the registration process to get vcs\tms to see the device has changed its IP? Id like to not have to go into the connection tab and updating the IP manually every time.
Thanks for any assistance
