SX10 connect via expressway no video
jeliasoncisco
Level 5
Level 5
We have Expressway C & E setup in our organization for Mobile and Remote Access with Jabber. When calling Jabber to Jabber we have two way video. However, after setting up a new SX10 remotely and calling an internal user on Jabber, the Telepresence unit is only sending audio, while the SX10 is receiving video from Cisco Jabber for Windows. Please note that this is not Telepresence Jabber, but regular Jabber 10.6.4
Could there be something I am doing wrong, or do we need special licensing to enable Video from the SX10 through expressway.
Thank you.
5 Replies 5
vikdutta
Please answer below questions.
Jabber to Jabber----->  A/V works fine
SX 10 to Jabber  -----> A/V doesn't works.
Question: 1. Is SX 10 registered over MRA on your CUCM.
                   2.   Is Sx 10 making a call over MRA or both Sx 10 and jabber are internally located
                      and making calls.
I know its a new installation, worth checking the self view of Sx 10.
//VD
Hello VD,
Please see my answers in line below. Thanks kindly.
Jabber to Jabber----->  A/V works fine - Correct
SX 10 to Jabber  -----> A/V doesn't work - Partial (Audio is fine through MRA, Video is not)
Question: 1. Is SX 10 registered over MRA on your CUCM - Yes
                      and making calls - Call over MRA
I know its a new installation, worth checking the self view of Sx 10 - Self View Video is working fine
Few things i can think of is mtp getting invoked due to codec mismatch or dtmf mismatch.
check the DTMF configured on Jabber and Sx 10 and set it to no preference.
Also, you may want to check the region and bandwidth settings for  both the devices.
Sip log will be more helpful in finding out whats going on with media. pcap on EC and EE can give clear picture.
Also,  you may want to get the medial port range verified on FW.
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X8-5/Mobile-Remote-Access-via-Expressway-Deployment-Guide-X8-5.pdf
Thanks.
//VD
ivansnchz1
hi, you can resolve this problem?
regards
One way audio or video is usually a firewall issue.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
