SX10 - how to access web interface behind a firewall
tomcropx2015
Howdy
I have a very basic setup, a home router and behind it SX10. I am unable to access the web interface of the unit remotely. Is there a port i need to enable or something?
When the unit was connected directly to modem, with public IP, I was able to connect the web interface.
any suggestions here?
I did not enter anything in the AllowRemote field.
thanks in advance!!
Patrick Sparkman
Web interface can be accessed ether using HTTP (80) or HTTPS (443).  Up to you how you'd want to deploy it, but you could use NAT on your router, port forwarding, or even put the SX10 in the router's DMZ.
If your router support static NAT (Network Address Translation), this would be possible.
regards,
Acevirgil
thanks!
Patrick Sparkman
tomcropx2015
thanks opening port 80 or 443 did the trick!
much obliged
