HD and Full HD
Leonardo Santana
I see on SX20 datasheets that supports this resolutions
  720p30 from 768 kbps
  720p60 from 1152 kbps
  1080p30 from 1472 kbps
  1080p60 from 2560 kbps
Its a stupid question wich one is HD and Full HD?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
2 Accepted Solutions
Magnus Ohm
You would have found the same answers with a quick google search but to answer your question:
720p also known as HD
1080p also known as FullHD
The number behind, 1080p"60" indicates frames per second. And the table shows you what bandwidth you need to achieve these resolutions.
/Magnus
720p30 and 720p60 are considered as HD and only difference is the frame rate (30 or 60) which determines the smoothness of the video. 1080p30 1080p60 are Full HD.
Bandwidth and considering the lighting condition have great impact in achieving video quality. Premium resolution option would be needed to achieve transmission of 1080p resolutions.
regards,
Acevirgil
Magnus Ohm
/Magnus
regards,
Acevirgil
