SX10 Problem to receive calls
Hi All
We´ve installed a SX10 (stand alone - w/o CUCM or VCS) and we did the basic configurations.
SIP Parameters
ANAT = off
DefaultTransport = Auto
Line = Shared
Listen port is = ON
Proxy 1 to 4 Address: emptyURI - company@publicIPaddress.
Topology: SX10---Catalyst 2690X - ASA5506X - Internet
In a Lap Top, we´ve installed the Linphone application (http://www.linphone.org/)  to make a test calls
All the calls from SX10 to the Linphone are stablished, but all the calls from linphone to SX10, didn´t work.
In this case, the SX10 ring, I accepeted the call, in the Linphone the call is aborted imeditelly, and at the SX10 cut the call after few (about 30) seconds.
Software version: ce 8.1.0 Final b8c0ca3 2016-04-05
Installed options: Encryption
someone already had this problem?
regards
Claudio Arriagada
6 Replies 6
Dennis Mink
can you include some logs re. SIP signalling, on yout Sx 20  got to diagnostics>log files, the eventlog/all.log contains the SIP messages. on your linphone, run wireshark and capture sip messages.  the issue is most likely caused by a capabilities mismatch, or an RTP port forward/translation from external to internal not working.
Please remember to rate useful posts, by clicking on the stars below.
Dennis,
see attached the files that you requested.
just to clarify, is a SX10 and not SX20, as you mentioned
thank you for your attention
regards
Claudio Arriagada
If your outbound calls are working, but your inbound calls are failing, then this is likely a firewall issue.  Make sure that you have opened up all the required firewall ports from the Internet to your endpoint.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne,
could you give me some tips about the firewall ports to be opened?
regards
claudio
https://supportforums.cisco.com/discussion/11606926/sx20-standalone is a good thread which tells you how to configure a standalone SX/EX/MX/Cseries endpoint and the firewall ports required.
Wayne
Wayne
Patrick Sparkman
CE8.2 introduced H323 support for the SX10, in addition to the other suggestions, it might help using H323 with NAT.  For firewall ports, refer to post mentioned by Wayne as well as the document Cisco (ex-TANDBERG) IP & SIP Firewall Ports.
