SX10 Video "Mute" or Disable
Jason Angelus
Is there a way to disable sending video while in a live call/session with the SX10?  nothing obvious appears in the TP control tablet or remote controls.
Thanks!
Patrick Sparkman
Only possible if you're using an MCU or TelePresence Server, you can mute/unmute your video and audio.  In a point-to-point call, you cannot.
jwilder
This feature was enabled in ce 9.8.0.
