SX10 WebEx registered Action button
David Winther
Does anyone know if it's possible to make a button on the touch panel that will function as a speed dial.? I know macro is not supported on the SX 10 but it has the ability to create an action button on the touch panel but can't seem to find out what I can do with it. The SX 10 is WebEx registered.
Wayne DeNardi
The addition of the buttons on the UI requires the Macro Framework - so this is not possible on an SX10.
You can use the FacilityService Service 1 option which will give you a small button at the top of the panel - not as obvious for a user to find, but can be used for a single speed dial option.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
