SX20 Codec stuck on Boot
Hello Everyone,
Since  a couple day i am looking for help. My sx20 codec stopped to work during a meeting (the display frozen). I tried to restart using the remote, no chance so i pressed the power button. After powered it on,  the power LED start to circle clockwise until now. I unplugged the power cable and plugged it back same. I tried to Reset the device using the factory reset step but it failed.
I am desperate, please assist or share your experience.
Telepresence, Conferencing
Thank you
Anurag Srivastava1
If it is not booting up even after factory reset then most probably its hardware issue.
will suggest to open a TAC case for RMA and get it replaced.
Please rate if it is helpful and mark as accepted solution if applicable...
Please rate if it is helpful and mark as accepted solution if applicable....
