(SX20) Listen a conference via the web interface
n.chouinard
Is it possible to listen to a conference between two SX20 codecs with their web interface?
Two codecs are in communication and I log on to the first web interface that has the web snapshot enabled. Am I able to hear the current conference? If yes, how?
If the web snapshot is not enabled, can I listen to the conference?
Thank you!
Patrick Sparkman
This is not possible, you must be connected into the same conference yourself as a participant using an endpoint if you want to monitor the conference.
Patrick Sparkman
